Formatting Dropdown Menu Selections
Hi TB Community!
How would I go about formatting - the "outcomes" from a dropdown menu, where multiple items can be selected?
I am hoping to have the options below, inserted/formatted into a numbered list
So the end result would look like:
  1. What are the current lease rates?
  2. When do those leases expire?
Thank you so much!
Andrew
Hi @ajduna7,
I tried creating a snippet to do that using {repeat}. Let me know if it works for you.
{note}{formmenu: Choice A; default=Choice B; Choice C; multiple=yes; name=choices}{endnote}
  1. {repeat: for index in seq(1, count(choices))}{=choices[index]}{if: index < count(choices)}
  2. {endif}{endrepeat}
This worked perfectly!! Thank you Ashwin :slight_smile:
