En Chile we use dots as the thousands separator as Spain but with the peso sign at the begining as mexican format. Can you add that base formatting to the configuration?
Thanks for the idea Nikolas.
To confirm, the correct format for Chile would be "$43.123,27"?
That is correct!
thanks you so much!
OK, we'll get this added! We'll let you know when it is out.
Hi @Nikolas_Torres_Niko , you can now select es-cl
as your locale on your settings page. Let me know if it works for you.
Thanks you so much! it working perfect.
