I am trying to insert an image into a snippet to be used in a text on Google Voice. When I insert the snippet (which contains the image) the image does not appear in the text. Is there a trick to getting this to work? An image size I should use? Or is it just not possible? Many thanks.
Hi @Michelle_Karlsson, welcome to the forum!
Inserting an image using Text Blaze is equivalent to pasting an image. Since Google Voice doesn't support pasting images into messages, Text Blaze can't do it either.
