Hide snippets from Chrome right-click context menu
Even though I am new to using Text Blaze, I've already run into having several snippets that exist purely to be used within other snippets. It would be great to be able to hide snippets (or entire folders' worth of snippets) from the right-click context menu in Chrome.
We're going to have some users for whom the right-click context menu will be the primary way in which they interact with Text Blaze and select snippets. I want to be able to guide them to the right snippet whilst decluttering the right-click context menu without having to try to bury folders at the bottom of the list with names like "[do not use]".
Hi Xam,
Thanks for this and your other feedback about restricting items to specific sites.
As you note, you can put things off in their own folders, but you can't currently hide things from the menu or disable them on specific sites.
In general, selecting from the list isn't the ideal way to use Text Blaze as typing a shortcut is much faster. Ideally, your users will learn to just use the snippet shortcuts. That way, they won't need to use the context-menu list at all.
