I would like to highlight and replace a single paragraph within a Google Doc. I have used: {key: ctrl-a; mac=cmd-a}{key: backspace} to replace all text, but I only want to replace one paragraph at a time. Any Ideas? Thanks!
Hi @Abby_Buccino Welcome back to the forum! ![]()
There's no way to delete entire paragraph at a time. You can use the following:
{repeat: 10}{key: ctrl-shift-leftarrow}{endrepeat}{key: backspace}
To delete the previous 10 words (for example) from your current cursor position. It is not the same as deleting the entire paragraph, but it's reasonably close.
Thanks Gaurang! This is really helpful ![]()
