Hello,
I am trying to use snippets to customize the rubric I use in feedback for my students. I want to be able to easily highlight bullet points in a rubric so they know what to focus on. The only way I have found to do this is to create an "if" statement using the same statement but one is highlighted. Then, using a form toggle, swap the non-highlighted phrase for the highlighted version of it. I included the snippet but it would not allow me to highlight one of the sentences in each "if" statement, so you will just have to imagine that part.
I wanted to make sure that there was no easier way to do this since I will have to create this combination for every bullet point in every rubric that I use.
Thank you!
Jen
/5 Section 1: Question, Topic, Why People Should Care:
{formtoggle: default=no; name=1}{endformtoggle}{if: 1
== yes}I chose a question from the lesson.{else}I chose a question from the lesson.{endif}
{formtoggle: default=no; name=2}{endformtoggle}{if: 2
== yes}I clearly and thoroughly explained what this topic addresses.{else}I clearly and thoroughly explained what this topic addresses.{endif}
{formtoggle: default=no; name=3}{endformtoggle}{if: 3
== yes}I clearly and thoroughly explained why people should care about this topic.{else}I clearly and thoroughly explained why people should care about this topic.{endif}
