Hipaa Compliance
Are Data Blaze and/or AI Blaze HIPAA compliant?
I understand that Text Blaze is HIPAA compliant.
Thanks
Hi @drferenz - both AI Blaze and Data Blaze are currently not HIPAA compliant.
If you'd like to learn more about the current data security please email me at dan@blaze.today.
We'll keep you posted when AI Blaze and Data Blaze are officially HIPAA compliant.
As long as you don't put both a patient identifier and the patient's personal health information together, it would be HIPAA compliant. If you plan on using Data Blaze to store patient identification and personal health information, you would not be HIPAA compliant. Google sheets does have HIPAA compliant spreadsheets but does not integrate as well with Text Blaze. We use Google Sheets and Text Blaze together using the copy function to put data into Text Blaze.
Very interesting. I didn't realize that Text Blaze works in Google Sheets. Do you have an example of how you use the copy function in Sheets? Can you pull data from a sheet into a google doc with Text Blaze?
Hey @drferenz,
You can do an API call to Google Sheets to get its data and then use that in Text Blaze. You can run your snippet anywhere, including Google Docs. This guide may help.
Keep in mind this isn't as straightforward as using Data Blaze, but it's a great solution if it fits your use case.
