Hotkey for snippet
I think it would be so helpful to add a hotkey to the menu to get the cursor into the New Snippet field. For instance when I press my hotkey to bring up TextBlaze and the menu opens, press a hotkey such as ALT+S and the cursor goes right to the Add Snippet box to enter a new snippet. Same with the button at the top that says SAVE. I do not like using my mouse and use my keyboard for everything so this would be so helpful for my production.
Hey Carol, thanks for the interesting suggestions.
Can you clarify what you mean here? Which hotkey are you referring to in this case?
Oh I like this idea! The biggest problem I've had with Text Blaze is not being able to remember the snippets. So setting up a hotkey that opens a pop-up where the cursor is would be very helpful. The Save Snippet in window feature is a great one too.
Edit: Oh I just noticed we can right-click and these options are already there!
Hi Tandon!
I'll try to explain it better. I use TB as an extension in Chrome. I press Alt+L and a box opens up and I tab over to "New Snippet". At that point the dashboard opens and I have to use the mouse to put the cursor in the field where I would create a new snippet. I wonder if we can have the option to create a hotkey to get the cursor to automatically jump to that field so that we can add a snippet. This would be more productive in my opinion.
I hope that is more explanatory. I don't know how else to word it.
Regards
I had a little time to write a walkthrough of effective ways to stay organized when you have a lot of snippets in Text Blaze. While this isn't a solution to keyboard shortcuts, this audience might find it helpful: Can't remember your shortcuts? A few solutions
@anon88096536 Thanks, that makes sense. So, as I understand it, you want different kinds of hotkeys to click into different buttons and boxes inside of https://dashboard.blaze.today. Right now, sadly, that's not possible. But I agree with you it'd be useful to have that functionality.
As a workaround for now, you can use the Vimium Chrome extension to navigate around the dashboard (and any other internet website) using its f shortcut. The extension is a bit technical to get started, but it's a breeze once you get used to it.
Thank you Tandon! I will check that out :slight_smile:
