Hi everyone,
I'm trying to understand the limitations of the Basic and Pro versions of Text Blaze. Specifically, I'd like to know:
* How many snippets can I create with the Basic (free) plan?
* How many snippets can I create with the Pro plan?
* Are there any other request or usage limits I should be aware of (e.g., Data Blaze queries, API calls, etc.)?
I want to make sure I choose the right plan for my needs. Any info or personal experience would be greatly appreciated!
Thanks in advance!
Welcome to the forum @mhprotic!
You can have 20 active snippets on the Basic (free) plan.
On the Pro plan, you can have up to 100 snippets per folder.
On the basic plan, you can trigger snippets with Pro commands only 5 times a day. There is no such limitation on the Pro plan.
In Data Blaze on the Basic plan, there is a 10,000-row limit per space and a 50,000-row limit on the Pro plan.
You can always start with the Basic (free) plan and upgrade to Pro in the future. You can also always downgrade back to the Basic plan from Pro.
