Hey everyone ![]()
How much do documentation errors cost your practice?
Instead of risking costly mistakes, use AI Blaze to review your notes and correspondence to help ensure they follow guidelines and requirements ![]()
AI Blaze can help you:
- Rewrite notes to make them adhere to guidelines and requirements.
- Proofread notes to check for mistakes or missing information.
- and much more!
Try it out!
What kind of prompts do you use? Feel free to post any below if you are comfortable with sharing ![]()
Try out these example prompts from the video:
Rewrite this text to ensure it meets medical documentation standards and is suitable for insurance review and billing.
### Instructions
The revised version should be:
- Accurate: Reflect exactly what was observed, done, or reported by the provider without exaggeration or omission.
- Complete: Include all relevant components (history, physical exam findings, clinical decision-making, interventions, and patient responses) to support medical necessity.
- Clear and professional: Use standard medical terminology and avoid ambiguous or vague language.
- Compliant: Align with CMS, E/M, and payer-specific documentation requirements (e.g., specifying time spent, using precise diagnoses, avoiding unsupported claims).
- Emphasize justification of medical necessity, especially for any tests, procedures, referrals, or treatments.
- Clearly link symptoms or findings to diagnosis and treatment plans. Avoid redundancy and filler language unless it contributes to billing or clarity.
- Maintain all information from the original notes. Don't add any additional information.
### Positive examples of what to include:
- “The patient presents with acute right lower quadrant abdominal pain lasting 12 hours, with associated nausea and anorexia. Differential includes appendicitis vs. ovarian torsion.”
- “A 12-lead EKG was obtained due to patient’s complaint of chest pain; it showed normal sinus rhythm. This supports ruling out cardiac ischemia.”
- “Time spent: 30 minutes in total, with over 50% devoted to counseling and coordination of care regarding new diagnosis of Type 2 Diabetes.”
### Negative examples to avoid:
- “Patient feels sick.” → Too vague; specify symptoms.
- “Did labs.” → Instead, say “Ordered CBC and CMP to evaluate for infection and metabolic abnormalities.”
- “Follow-up as needed.” → Be specific: “Follow-up in 2 weeks to reassess blood pressure control."
Proofread these notes to call out mistakes, errors, missing codes, or missing/incomplete information.
### Instructions
- Proofread the notes and identify and mistakes or missing info.
- Maintain all accuracy and medical information.
- Verify language used is correct and professional and compliant.
### Sample output
Errors {{^^%E2%9D%8C^^}}
- Text
- Text
- Text
Missing codes {{^^%F0%9F%A9%BA^^}}
- Code 1
- Code 2
Missing information {{^^%F0%9F%93%8B^^}}
- Text
- Text
