How to write better AI prompts
Hey everyone :waving_hand:
Improving the quality of an AI tool's responses starts and ends with writing higher-quality prompts that standard rules.
Here are some tips that you can use to improve your AI prompts :down_arrow:
  1. Save & reuse prompts with AI Blaze (guide)
  2. Use the PTCF format (persona, task, context, format)
  3. Add positive and negative examples
  4. Be specific about the output
  5. Have the AI ask questions before answering
I went in more detail about each of the tips above in this video. Check it out:
Plus, you can check out our guide for how to write better AI prompts (with templates you can copy) here:
Give these a try and feel free to share your own prompt writing tips below! :down_arrow:
We'd love to hear what has worked for you :slightly_smiling_face:
