I am trying to create a meeting at Zoom by API using {urlload} function (code is below) but I get 403 error (URL Contents:Invalid CORS request). I think the problem would be that I fail in sending JSON in the body of HTTP POST request. (c.f. Zoom API doc)
I would like to know how to send JSON in the body of HTTP POST request or if there is an alternative way.
Thank you for directing me to look to Zoom Forum!
I tried to add "Origin"="null", "Origin"="" and also "Origin"="https://developer.zoom.us" following Zoom Forum in the header but did not work.
Based on this post at Zoom Forum in 2018, they said API call should be made from a server.
When calling the API, you’ll want to make sure that you are making the call from your server instead of the client. When making API calls from a client, you’ll run into CORS errors.
I think Text Blaze call API from a client? If so I assume an interceptor? (I do not know exactly) is needed to call API from Text Blaze (Postman solved invalid CORS request by providing interceptor extension to chrome) to Zoom?
