Hey everyone ![]()
Have you ever struggled with finding time for writing patient assessments?
Instead, use AI Blaze to write & review patient assessments in a fraction of the time it takes to do it manually ![]()
AI Blaze helps you:
- Write assessments from scratch by reading visit information
- Review assessments you wrote to check for mistakes
- Rewrite rough assessments to make them adhere to your requirements
- Much more!
If you haven’t yet, please give AI Blaze a try and let us know what you think. ![]()
Example prompts
Give these example prompts from the video a try ![]()
Act as a healthcare professional assistant. Based on the provided patient visit information, create a comprehensive assessment with the following requirements:
## Instructions
- Write a detailed assessment that summarizes the patient visit
- Provide a clear diagnosis based on the clinical findings
- Justify the treatment plan with medical reasoning
- Include medical necessity justification for any CPT codes used
- Use professional medical terminology while maintaining clarity
- Follow standard medical documentation practices
- Put Assessment (SOAP A) at the top in bold
## Sample output
Assessment (SOAP A)
[assessment here (one paragraph of text)]
Act as a healthcare documentation specialist. Please thoroughly review the provided assessment and provide feedback on the following areas:
## Instructions
Content Completeness:
- Check if all relevant clinical findings are documented
- Verify that the assessment addresses the patient's chief complaint
- Ensure all body systems mentioned in the examination are properly assessed
- Identify any missing differential diagnoses or clinical considerations
Clinical Accuracy:
- Review diagnostic reasoning and clinical logic
- Check for consistency between subjective findings, objective data, and assessment
- Verify that treatment plans align with the documented diagnoses
- Flag any potential clinical red flags or concerning findings that may need attention
Documentation Quality:
- Ensure clear, professional medical language
- Check for proper medical terminology and spelling
- Verify that the assessment flows logically from history and physical exam
- Confirm that all abbreviations are appropriate and clear
Billing and Reimbursement Optimization:
- Identify appropriate ICD-10 diagnostic codes based on documented conditions
- Suggest CPT codes for documented procedures or services
- Highlight opportunities for additional billable services that were provided but not documented
- Check for specificity in documentation that supports higher-level billing when appropriate
- Identify any missing documentation that could impact reimbursement
Compliance and Risk Management:
- Ensure documentation meets medical necessity requirements
- Check for proper informed consent documentation when applicable
- Verify that all required elements for the level of service are documented
- Identify any potential liability concerns or missing protective documentation
## Sample output
Feedback:
- text
- text
Rewritten Assessment
[rewritten assessment]
Changes
- text
- text
- text
CPT Codes:
- text
- text
