Hi Text Blaze Community,
Is it possible to use "if conditions" to change the color of a variable? For example:
Total Cholesterol (TC): {formtext: name=TC} mg/dL
If TC <200 = Green text, If TC 200-240 = Yellow text, If >240 = Red text
I need the number and units to turn color based on the variable value.
Thanks in advance for your help!
Hi @Abby_Buccino welcome to the forum!
You would need to create separate parts for each condition and then apply color to each part separately.
{formtext: name=value}
{if: value > 240}
red text
{if: value >= 200 and value <= 240}
yellow text
{if: value < 200}
green text
(forum doesn't support colored text which is why the above texts will all appear uncolored)
Further if you have a variable that needs to be colored, you can do that too.
{if: value > 240}
{=value}
{=value}
{if: value < 200}
{=value}
In the above snippet, you can select the =value chip using your mouse and then apply color to it.
Let me know if that helps.
I just wanted to send a very delayed thank you! This has helped me and my team tremendously!
