When I attach images, they don't appear when I use the shortcut, could you help me
Hi @Alessandro - is it possible to paste an image in the text box where you use Text Blaze? Images in snippets will only work if it's possible to paste an image in that text box.
Is it possible to paste images directly into the text box when using Text Blaze snippets?
Yes, including images in snippets will paste them in the text box, as long as the text box supports pasting images. You can try it by copying any image and trying to paste it into that text box.
I have copied an image inside the snippet, however while recalling the snippet only the text is shared
here is the snippet link - Copy of snippet "RTHK Vote 1"
Hi @Bharat_Nangia
Which app/website are you running this snippet inside?
WhatsApp on Microsoft edge on a Desktop PC
This is usually due to the functionality of the platform, such as WhatsApp, where you're trying to insert the snippet.
When you use a Text Blaze snippet that contains text and images, it's as if you were copying the whole thing into your computer's clipboard and pasting it somewhere.
Some platforms will allow you to paste an image on its own, or text on its own, but not a combination of both. WhatsApp is one such platform.
Unfortunately, Text Blaze cannot workaround the platform's limitation at the moment.
