I can insert basic dropdowns into snippet using dropdown feature. But this requires me to manually add fields. Also, its limited in the amount of data i can add. For instance, I am creating a superprompt for ChatGPT and want to select from a list of scientists that i have in the table on DataBlaze. For each scientist there, i have several column, like theories, keywords, papers, etc. Depending on request, i want to quickly choose what i want to add to the superprompt for ChatGPT to consider when creating an answer.
I cannot figure out how to get data from the table in data blaze show up in a Snippet Form for me to select the scholars.
Hey @Mikhail_NYC and welcome to the forume. What you're looking for is the read from table command that allows you to select one or more rows from a table and use the information in a snippet.
Here's an example:
This is beyond awesome. All of this. Quick question for you.
when the menu pops us in the form, the font is really big and its only a single line.
how can i make that font much smaller and wrap it.
I have sets of instructions that i need to choose from, but i can only see the first few words.
I tried changing the size of the font to Small, but when i run the snippet, it does the same thing, and when i return, the font is back to normal.
Hello dan,
You can no longer see these fragments. Can you update please?
You really need this trick.
I need to show a dropdown field because the dropdown field of the read command complicates my work
