I am trying to add a new snippet with a hyperlink, but the 'Insert Link' button shows as grey and I'm not able to create a hyperlink for the snippet.
Is this happening for anyone else, any possible workarounds with this?
Hi, and welcome to the forum!
You need to select the text you want to convert to a hyperlink and then press the button. Let me know if that works.
Things do look a little strange in your screenshot though. Do the other styling commands work (e.g. bold)? What web browser are you using?
Hey Scott,
Thanks for your response. I've created hyperlinks that way in the past, but it doesn't work for me anymore unfortunately.
Every other styling command works even though some of them are in that light grey color, it's just the hyper link button that doesn't work. I use the most up to date version of Google Chrome
Hi @Will_Sloat ,
Can you try a different browser to see if you see the same issue.
I am wondering if any of your extensions is conflicting the logic.
hey Vinod - what other extensions can I use TextBlaze with? When I go to add it in Safari it says it's only an extension for Google Chrome...
Hi @Will_Sloat try out our desktop app for macOS
the desktop app allows me to edit links, thank you!
