Insert without closing
I have a unique template that has a lot of questions with it's answers, but I need to open it or use the command to insert the information, It would be really awesome if we could improve or add a way to insert the template but keep the snippet open or ready to insert again, thanks for reading this.
Hi @Aldo_Barahona, welcome back to the forum! :slight_smile:
Thanks for sharing the feature idea with us! Can you please tell us a bit more about your use case? For example, where and how do you want to use this snippet, and do you usually need one answer at a time or do you want to provide multiple answers together?
That way we can better understand what you need or work out a workaround together with the existing Text Blaze features.
This is the snippet I use, I evaluate calls and sometimes I make multiple deductions on the same call and just would like to insert the text without having to use the command again every time I make deductions, and instead just insert the info and if I need to make another deduction then place the cursor where I want to insert the text and just insert it with no more actions. Hope this make sense
{note: color=none}{formmenu: default=; 4. Did the agent open the call with a Friendly Branded Greeting?; 5. Did the agent leverage active listening skills?; 6. Was the agent’s closing polite and thorough?; 7. Did the agent follow all Soft Skill Procedures?; 8. Did the agent empathize with the member when applicable?; 9. Did the agent maintain a professional demeanor throughout the interaction?; 10. Did the agent ask probing/clarifying questions to get to the root of the problem?; 11. Did the agent select the correct form? Unauthorized/Authorized transaction?; 12. Did the agent cancel and reorder a card due to the unauthorized transactions?; 13. Did the agent ensure to follow ALL of the correct procedures, where applicable?; 14. Did the agent provide accurate and complete information?; 15. Did the agent leave appropriate and complete notes?; 16. Was the contact verified correctly per procedure?; 17. Was the contact verified prior to the release of application or account‑specific information?; 18. Did the agent avoid discussing items of a prohibited basis with this interaction (ECOA)?; 19. Did the agent follow all UDAAP requirements?; 20. Did the agent avoid discouraging the caller from applying or taking further action on the account or application?; 21. Did the agent follow all Reg B policies to withdraw an application?; 22. Were all required disclosures provided?; 23. Required Disclosures – Call Recording Disclosure; 24. Did the agent file a complaint on behalf of the member?; 25. Did the communication fall within appropriate TCPA hours?; 26. Did the agent follow correct opt‑out procedures if the member requested no further contact?; 27. If provided, were timelines accurate and in compliance with requirements outlined in applicable procedures?; 28. Did the agent prevent the transmission of PII in any interaction with the member?; \ 29. Did the agent avoid filing a complaint when it was not necessary?; name=formmenu171}{endnote}{if: formmenu171 = ""; trim=right}{elseif: formmenu171 = "4. Did the agent open the call with a Friendly Branded Greeting?"; trim=yes}
When the menu selection is "4. Did the agent open the call with a Friendly Branded Greeting?", this will show.
{elseif: formmenu171 = "5. Did the agent leverage active listening skills?"; trim=yes}
When the menu selection is "5. Did the agent leverage active listening skills?", this will show.
{elseif: formmenu171 = "6. Was the agent’s closing polite and thorough?"; trim=yes}
The closing of the interaction did not fully meet expectations due to missed procedural steps. A strong closing is important because it ensures the member feels supported, confirms that all concerns have been addressed, and provides a professional end to the conversation.
MTP we can use.
“Today, we reviewed your concern regarding [issue] and completed [resolution]. Is there anything else I can assist you with today?”
SOP:
{elseif: formmenu171 = "7. Did the agent follow all Soft Skill Procedures?"; trim=yes} {formmenu: Hold; Procedure; name=Question 7; multiple=yes}{if: includes(`question 7`, "Hold")}{formmenu: Mute; Dead Air; More than 3 minutes; No Confirmation; name=hold; multiple=yes}{endif}{if: includes(`question 7`, "Procedure")}{formmenu: Cold Transfer; name=Procedure; multiple=yes}{endif}
{if: includes(hold, "Mute")}We remain in silence for more than {formtext}.
Per SOP:
Any research or review of an account that takes 20 seconds should result in the agent requesting permission from the member to initiate a hold.
Mute SHOULD NOT be used a substitute to placing the member on hold{endif}{if: includes(Procedure, "Cold Transfer")}
During the call we mentioned to the member that we were going to transfer the call but we did not do a warm transfer with the receiving agent, as per SOP we must ensure we do warm transfer on every interaction, ensure that we follow the correct procedure for transfers on every interaction.
Per SOP:
Calls must be warm transferred unless the internal queue has an extended wait time. (Guidelines are provided below). Attempt to locate a profile in Atlas.
{endif}{if: includes(hold, "More than 3 minutes")}
We placed the member on hold for more than {formtext}.
Per SOP:
If an expectation is not set, the agent is required to check back with the member every 3 minutes.
If an expectation is set with the member, check back with the member at the appropriate time. For example, if you say, "May I place you on a brief hold for 2 minutes?” you must check back in at 2 minutes with the customer.{endif}{if: includes(hold, "No Confirmation")}
We should tell the member we are going to place them on hold and get confirmation from the member.
Do not say, “Hang on a second, I’ll be right back.”
Kindly ask the member if you can place them on hold, “Do you mind if I place you on a brief hold while I research your account?”{endif}
SOP:{if: includes(`Hold`, "Mute") or includes(`Hold`, "Dead Air") or includes(`Hold`, "More than 3 minutes") or includes(`Hold`, "No Confirmation")}{elseif: includes(`Procedure`, "Cold Transfer") }{endif}
{elseif: formmenu171 = "8. Did the agent empathize with the member when applicable?"; trim=yes}
The member had issues with {formtext}, but we did not show empathy with the member because of that.
We could have said: " I understand the importance of getting this resolved, let me see what I can do about it".
SOP:
{elseif: formmenu171 = "9. Did the agent maintain a professional demeanor throughout the interaction?"; trim=yes}
Tone is everything. Our communication should be positive, enthusiastic, and demonstrate a genuine commitment to helping others, During the call we sounded
{elseif: formmenu171 = "10. Did the agent ask probing/clarifying questions to get to the root of the problem?"; trim=yes}
When the menu selection is "10. Did the agent ask probing/clarifying questions to get to the root of the problem?", this will show.
{elseif: formmenu171 = "11. Did the agent select the correct form? Unauthorized/Authorized transaction?"; trim=yes}
When the menu selection is "11. Did the agent select the correct form? Unauthorized/Authorized transaction?", this will show.
{elseif: formmenu171 = "12. Did the agent cancel and reorder a card due to the unauthorized transactions?"; trim=yes}
We missed replacing the debit card to avoid further unauthorized transactions, ensure that we report the debit card once we know the transaction was not authorized.
Per SOP:
Replacing the debit card is required by MasterCard and reduces the risk of any additional unauthorized charges to the member and the company.
Intaking Unauthorized Debit Card Disputes Procedure, Bank/Money (Fraud COE) - Operations - SoFi Confluence{elseif: formmenu171 = "13. Did the agent ensure to follow ALL of the correct procedures, where applicable?"; trim=yes}
{note: color=none}{formmenu: Over Explaining ETA; Unau Pending not file; ; ; name=Question 13; multiple=yes}{endnote}{if: includes(`question 13`, "Over Explaining ETA")}
Ensure to avoid over explaining the member with timelines, we need to ensure we use the MTP in step 6, and if the member ask for more information regarding timelines, then we explain about the 10-business timeframe or the 90 days but avoid to proactively giving this information if the member is not asking for it.
Per SOP
I MTP | You will receive an email confirming your dispute has been filed. We typically resolve disputes within a few days of submission. Once our review is complete, we’ll send the results in writing within 3 business days. If we need additional information, we’ll contact you by email.
Unauthorized Debit Card Disputes Procedure, Bank/Money (Fraud COE) - Operations - SoFi Confluence{endif}{if: includes(`question 13`, "Unau Pending not file")}
We are now able to dispute transactions even though they are pending but as long as it is unauthorized we can dispute it and since the member mentioned at the beginning of the call that the transaction was unauthorized or fraudulent we could have dispute this transaction, ensure to check the SOP so we can be on top of the actions to take and provide a better member resolution.
Per SOP: Step 2 | Locate the transaction in SoFi Atlas.
Note: A dispute can be filed on Pending and Posted Unauthorized transactions. Pending transactions are located under Pending on the Transaction tab in
SoFi Atlas.
Intaking Unauthorized Debit Card Disputes Procedure, Bank/Money (Fraud COE) - Operations - SoFi Confluence{endif}
{elseif: formmenu171 = "14. Did the agent provide accurate and complete information?"; trim=yes}
Ensure we keep member expectations realistic and that we cannot in any way imply that we are "escalating" or putting "priority" on a dispute or other process that we need to escalate as all disputes or escalations are processed equally based on when they are received.
SOP:
{formparagraph: cols=30; rows=6}{elseif: formmenu171 = "15. Did the agent leave appropriate and complete notes?"; trim=yes}{note: color=none}{formmenu: General; No Notes; ZD Ticket; Timeframe; Transaction Details; name=Question 15; multiple=yes}{endnote}{if: includes(`question 15`, "General")}
{formparagraph: cols=10; rows=2}{endif}{if: includes(`question 15`, "No Notes")}
We did not leave notes in the member's profile, we need to ensure we add as much information as possible in our notes.
Per SOP:
Capture as much of what was said as possible.{endif}
{if: includes(`question 15`, "ZD Ticket")}Ensure to add the Zendesk ticket related to the dispute the member is calling for, as per SOP we must add this relevant information in our notes.
Per SOP:
Add details regarding tickets and form
~ Include in the note:
Ticket
Type of ticket and ticket number
Form
Reference to the form name{endif}
{if: includes(`question 15`, "Timeframe")}
{formparagraph}
Per SOP:
Notate specific timelines and follow-up expectations
Examples:
Confirmed research may take 1-2 business days
Member requested outbound call follow-up{endif}
{if: includes(`question 15`, "Transaction Details")}
We did not add the transaction details in our notes, such as the merchant's name and amount, ensure we add all relevant information in our notes.
Per SOP:
SOP:
{elseif: formmenu171 = "16. Was the contact verified correctly per procedure?"; trim=yes}
When the menu selection is "16. Was the contact verified correctly per procedure?", this will show.
{elseif: formmenu171 = "17. Was the contact verified prior to the release of application or account‑specific information?"; trim=yes}
When the menu selection is "17. Was the contact verified prior to the release of application or account‑specific information?", this will show.
{elseif: formmenu171 = "18. Did the agent avoid discussing items of a prohibited basis with this interaction (ECOA)?"; trim=yes}
When the menu selection is "18. Did the agent avoid discussing items of a prohibited basis with this interaction (ECOA)?", this will show.
{elseif: formmenu171 = "19. Did the agent follow all UDAAP requirements?"; trim=yes}
When the menu selection is "19. Did the agent follow all UDAAP requirements?", this will show.
{elseif: formmenu171 = "20. Did the agent avoid discouraging the caller from applying or taking further action on the account or application?"; trim=yes}
When the menu selection is "20. Did the agent avoid discouraging the caller from applying or taking further action on the account or application?", this will show.
{elseif: formmenu171 = "21. Did the agent follow all Reg B policies to withdraw an application?"; trim=yes}
When the menu selection is "21. Did the agent follow all Reg B policies to withdraw an application?", this will show.
{elseif: formmenu171 = "22. Were all required disclosures provided?"; trim=yes}
At minute {formtext} > Another person joined the call and we should have stated the call recording disclosure but we missed this, ensure as soon as another person joins the call we provide the call recording disclosure.
Per SOP:
  • A new person joins the call on the member's end after the disclosure has been provided.
{elseif: formmenu171 = "23. Required Disclosures – Call Recording Disclosure"; trim=yes}
When the menu selection is "23. Required Disclosures – Call Recording Disclosure", this will show.
{elseif: formmenu171 = "24. Did the agent file a complaint on behalf of the member?"; trim=yes}
When the menu selection is "24. Did the agent file a complaint on behalf of the member?", this will show.
{elseif: formmenu171 = "25. Did the communication fall within appropriate TCPA hours?"; trim=yes}
When the menu selection is "25. Did the communication fall within appropriate TCPA hours?", this will show.
{elseif: formmenu171 = "26. Did the agent follow correct opt‑out procedures if the member requested no further contact?"; trim=yes}
When the menu selection is "26. Did the agent follow correct opt‑out procedures if the member requested no further contact?", this will show.
{elseif: formmenu171 = "27. If provided, were timelines accurate and in compliance with requirements outlined in applicable procedures?"; trim=yes}
When the menu selection is "27. If provided, were timelines accurate and in compliance with requirements outlined in applicable procedures?", this will show.
{elseif: formmenu171 = "28. Did the agent prevent the transmission of PII in any interaction with the member?"; trim=yes}
When the menu selection is "28. Did the agent prevent the transmission of PII in any interaction with the member?", this will show.
{elseif: formmenu171 = "\ 29. Did the agent avoid filing a complaint when it was not necessary?"; trim=yes}
When the menu selection is "\ 29. Did the agent avoid filing a complaint when it was not necessary?", this will show.{endif: trim=left}
Hi @Aldo_Barahona, thanks for sharing your use case with us.
Would multi-selection help? You can set multiple=yes for the formmenu, then use {repeat} to loop over the deductions you selected and {if} to insert the text for each pick. So you can pick all the deductions related to the call in one go and insert them together in the order you selected them, as follows:
{note: color=none}{formmenu: 6. Was the agent’s closing polite and thorough?; 12. Did the agent cancel and reorder a card due to the unauthorized transactions?; name=formmenu171; multiple=yes}{endnote}{repeat: for item in formmenu171}{if: item = "6. Was the agent’s closing polite and thorough?"}The closing of the interaction did not fully meet expectations due to missed procedural steps. A strong closing is important because it ensures the member feels supported, confirms that all concerns have been addressed, and provides a professional end to the conversation.
MTP we can use.
SOP:{elseif: item = "12. Did the agent cancel and reorder a card due to the unauthorized transactions?"}We missed replacing the debit card to avoid further unauthorized transactions, ensure that we report the debit card once we know the transaction was not authorized.
Per SOP:
{endrepeat}
This way, you can keep the pop-up open until you're done with all your picks, then insert them all together.
Please let me know if it helps.
not really because they are different questions, meaning that I insert and I move to other question to insert the information, hope it makes sense
@Aldo_Barahona Thanks for clarifying your use cases. We'll look into it and see if there's a chance to implement that feature in the future.
