Instant Assistant feature
Hello,
Is anyone else experiencing issues with the Instant Assistant feature? It’s currently not showing on my end, as illustrated in the image below. It appears to be missing from its usual location/interface.
Could you please look into this and advise on the next steps to resolve the issue?
So when you start typing a shortcut, you are not getting your version of this?
Yes its not showing
How can we fix it?
Do we have an option to enable it back?
Hi John, I've responded to your email. This was an experimental feature that was available only to a small group of users. We're slowly removing this feature as we work on a new, improved version of it.
In the meantime, we recommend using the Text Blaze Assistant (https://www.youtube.com/watch?v=IIWQbcqH8mQ&t=0s) to search and insert your snippets. Let us know if you face any issues with the Assistant.
Thanks for your understanding! Best,
Gaurang
Can we enable it please on my account i badly need it
