Is it possible to set up a workflow in TextBlaze to snippet your current IP Address or location?
Hi @Edward_Darrah,
In theory you could use the {urlload}
command in conjunction with a website that provides your IP and location to read that data and insert it in a snippet.
Could you tell me a bit more about the workflow you had in mind please?
Thanks for the suggestion; I will look into this command option. I work in healthcare, and the IP is typically needed on all files. I am finding it difficult to add an IP address to a Google Doc. I thought this could be a good option to capture a location quickly.
