I need build a fairly long list of options in several dropdown elements. Is there a way to by-pass entering each one and import the list? Full disclosure: I am brand new to Text Blaze. I know enough javascript, HTML, and Playwright to be dangerous.
I usually work with WordPress, but I'm using Text Blaze to speed up data entry for an auction application that's used by a 501(c)3 that I volunteer with. Text Blaze is perfect for what I'm trying to achieve. I started working with it on Saturday afternoon, and so far I've gotten our two main issues addressed with two snippets and chrome extension that pops up a page that we need to run one of the snippets on. Granted, I stayed up until 1 AM this morning to get it all done, but it's nothing compared to the hours I've spent working with other packages that didn't quite do the job.
Thanks for any insight because I may have very well missed something obvious.
Hi @Mary_Walker and welcome to the forum!
Yes, there is values
setting on a formmenu which you could use to pass a list of options. I've added a small example below.
{options=["Option1", "Option2", "Option3", "Option4"]}
{formmenu: name=dropdown; values={=options}}
Thanks, Mansur! I hadn't realized what the values field did. I discovered Data Blaze last night, and it's doing what I'd envisioned. I know it's risky to use something in beta, but it looks promising.
Is it possible to allow multi-select with this? I am coming from PhraseExpander (or at least considering it) and I have some multi-select fields with 30 or 40 values that I would really rather not retype one option at a time in Text Blaze.
Welcome to the forum @textblaze5!
Yes, it is possible. You simply need to enable the multiple
setting. Here is an example:
{formmenu: name=dropdown; values={=options}; multiple=yes}
Awesome, thank you.
But when I run the snippet, it is adding a comma between values. I don't want that. You can see that here.
@2014 John Deere For Sale, @2025 Taxes
You can use the note
command to prevent formmenu
command output and then use formmenu
name to output in the desired format. For example, all selected items on a new line:
{note}{options=["Option1", "Option2", "Option3", "Option4"]}
{formmenu: name=dropdown; values={=options}; multiple=yes}{endnote: trim=yes}
{repeat: for x in dropdown}{=x}
{endrepeat}
