I've been using this for a whole now an it helps me a ton with emails and commenting since my job is very repetitive, which leads me to copy and pasting data from one place to a text field usually to save time, so is it possible to copy one thing on a website and have it automatically paste into a text field?
Hello Ryan, welcome to the community!
You can use the {site} command to automatically pull data from any website and onto your snippet, so you don't have to copy paste anything. You likely need this specific section of the guide.
If you need any help setting up the selector for the command, feel free to email me at obed@blaze.today and I can help out.
Awesome, thaknkyou! giving it a try now.
Is there a way to just do a regular copy of info from another site and pasting it into a field, like you do with regular excel? I need to be able to copy patient numbers and names into my fields to track payments for services and I can't find a way to do that.
Hi, and welcome to the forum! ![]()
Yes, you can access parts of the page you are on or other tabs using the {site} command.
You can learn more about the site command here:
I recommend watching the video on the page to get an overview of the capabilities.
