Keep Pop-up Open After Copying Text
Hello,
I have a quick question. When I use AI Blaze to generate a message, the pop-up automatically closes as soon as I copy the text.
Now that I'm using it to generate both a message and a title, it would be really helpful if the pop-up could stay open—so I can copy multiple pieces of text without having to regenerate each time.
Is there a fix or setting that would allow this?
Thanks in advance!
Hi :waving_hand:
As of right now, this is the expected behavior for the chat window.
Though, when you copy some text and the window closes, you can click the history icon to reopen the chat and then copy the other text.
I understand why you'd want the window to stay open though. I have changed this to a feature request and we will consider it.
We appreciate your feedback on AI Blaze!
Thanks, Dylan, really appreciate your prompt answer.
By the way, I am a huge fan of your solution, I am working in a large company, and won't hesitate to promote your solution for some specific use cases. Keep up the good work.
Thanks :slight_smile:
We appreciate your feedback and support! Feel free to let us know if you have any additional questions or feedback.
