Is it possible to have a new link break within the same submenu?
For example, have "please select dialysis" under "please select chronic kidney disease" instead of appearing right after it.
Any advice or recommendations for a new snippet format is appreciated.
You can achieve this by modifying the itemformatter field of your Dropdown command. Using the code (value) -> value & "\n" will add a new line after each field.
However, this won't work in the snippet preview (when showing what you have selected) only when the text is inserted.
