If you've ever used Linkedin Recruiter, you know it can be a import profiles from a search to a project. It requires you either to click each profile directly or to import 25 at a time before needing to paginate to the next page. Well, not anymore!
Just start within a "Search Screen" with the search already tagged to a project. Fire this bad-boy off and watch it work. Now even you can InMaul unsuspecting victims indescriminately!
It loops through the following sequence 20x :
- Select all 25 profiles on the page
- add all to project
- click next page.
{repeat: 20}{click: selector=.profile-list__header label} {click: selector=button[class*="save-to-pipeline__button"]} {click: selector=[data-test-mini-pagination-next]}{wait: delay=+3s}{endrepeat}
