LinkedIn Use with CRM?
I am a time management coach who has used and recommended text expanders for years.
Just found Text Blaze and am very impressed so far.
I noticed there is a number of LinkedIn functionalities and wondered if Text Blaze might solve a problem I am having.
I do a lot of prospecting on LinkedIn. My personal CRM, Nimble has a great Chrome extension that creates a new contact in Nimble from LinkedIn. Saves me a ton of time.
I have a client that uses Hubspot and I can't move him from Hubspot because of its integration with his support areas and website.
I would like a way to grab LinkedIn contact info of people we are connected to and add it to Hubspot. Sadly Hubspot doesn't have a similar Chrome extension to Nimble.
Is there a way I might be able to use Text Blaze for this?
Thanks,
Hi @CaptainTime , welcome to the forum.
HubSpot used to support API keys, which made it possible to write to HubSpot using a snippet. They now use OAuth, which is currently not supported.
You could save the information from LinkedIn into Data Blaze using a snippet and periodically export it to a CSV and import it to HubSpot.
Like @Dan_Barak1 mentioned, I will save information from linkedin to Datablaze and using webhook and using third-party tool (like Zapier, n8n, Make or Pabbly Connect), the information from Datablaze will be automatically added to Hubspot CRM (upon adding new row in Datablaze).
That will smoothly work.
How do you get the information from LinkedIn into Datablaze?
