Hello!
I have created my first snippets, and the hyperlink shows in the text box as well as when I test, but when I actually use the snippet, the links don't work.
Any ideas?
Could you please share the snippet you're trying to use? Also, on which website are you inserting the snippet?
Thanks for writing @Cedric_Debono_Blaze . It's a snippet I am using in email and text (with Google Voice).
It's a hyperlink
I just used the snippet here, and this is how it shows up:
Also, make sure to check out our recent reviews on Facebook, Google and Yelp.
(In my dashboard, each of the platforms are linked, though you can see they aren't anymore)
Can you please try using the {link} command? Here's what that looks like:
{link: http://google.com}Google{endlink}
