I want the ability to lock ranges of info in a snippet from being edited so that when making adjustments to the snippet, contents are not mistakenly edited that are not supposed to be.
For example, there is a batch of commands at the end of most of my teams snippets that has some variation depending on the snippet, but basically, looks like this:
{note: insert=yes; preview=no; trim=yes}{wait: delay=+0.5s}{import: |selectorcaseteam}{wait}{key: s}{key: t}{key: u}{key: d}{key: e}{key: n}{key: t}{key: space}{key: a}{key: d}{key: v}{key: o}{key: c}{key: a}{key: c}{key: y}{key: enter}{wait: delay=+0.5s}{import: |selectorcasetype}{wait}{key: c}{key: h}{key: a}{key: n}{key: g}{key: e}{key: space}{key: o}{key: f}{key: space}{key: e}{key: n}{key: r}{key: o}{key: l}{key: l}{key: m}{key: e}{key: n}{key: t}{key: space}{key: (}{key: r}{key: e}{key: -}{key: e}{key: n}{key: t}{key: r}{key: y}{key: )}{key: enter}{wait: delay=+0.5s}{import: |selectorcasesavebutton}{endnote}
It is imperative that these AutoPilot commands run exactly as coded every single time, with zero margin for error. I find that once in a while, when editing the contents of a snippet, a hotkey or something may be unknowingly hit which causes some of the snippet contents to change. I would love to be able to identify batches or ranges of content in my snippets that are locked from being edited. Perhaps such content could be wrapped in a something like {lock} {endlock}.
Thank you!
-Brad
