Got myself a new work PC, logged in and used Text Blaze.
This morning PC doesn't start, I sent it out for servicing.
I need to log out from Text Blaze on that PC, to which I don;t have access anymore.
How do I do that? Please help!
I am sure the support is quick but i would bet it would also work to change your password on a device you are logged in or log into. That SHOULD require your logged in work device to request the password again.
If you log in on another device, and then log out, that will log you out of all other devices.
