Hi Scott,
Below is an example of a toggle list with a long list of selections, of which only 3-5 will be selected at any one time. For ease of reading a vertical presentation is much easier than horizontal panel. However, when selected it would be convenient if they are listed closely together with no gaps in between, or above or below them when inserted into the document. Can you help.
Thanks in advance
George M
Below is the snippet:
{formtoggle: name= Associated_symptoms; formatter=(value) -> "" if value else ""}{if: Associated_symptoms}
{formtoggle: name= Heartburn; formatter=(value) -> " Heartburn." if value else ""}
{formtoggle: name= Acid or food regurgitation; formatter=(value) -> " Acid or food regurgitation." if value else ""}
{formtoggle: name= Throat irritation; formatter=(value) -> " Throat irritation." if value else ""}
{formtoggle: name= Cough; formatter=(value) -> " Cough." if value else ""}
{formtoggle: name= Hoarse voice; formatter=(value) -> " Hoarse voice." if value else ""}
{formtoggle: name= Post-prandial fullness; formatter=(value) -> " Post-prandial fullness." if value else ""}
{formtoggle: name= Early satiety; formatter=(value) -> " Early satiety." if value else ""}
{formtoggle: name= Loss of appetite (anorexia); formatter=(value) -> " Loss of appetite (anorexia);." if value else ""}
{formtoggle: name= Weight loss; formatter=(value) -> " Weight loss." if value else ""}
{formtoggle: name= Nausea; formatter=(value) -> " Nausea." if value else ""}
{formtoggle: name= Vomiting; formatter=(value) -> " Vomiting." if value else ""}
{formtoggle: name= Excessive burping; formatter=(value) -> " Excessive burping." if value else ""}
{formtoggle: name= Excessive belching; formatter=(value) -> " Excessive belching." if value else ""}
{formtoggle: name= Constipation; formatter=(value) -> " Constipation." if value else ""}
{formtoggle: name= Diarrhoea; formatter=(value) -> " Diarrhoea." if value else ""}
{formtoggle: name= Marked abdominal bloating; formatter=(value) -> " Marked abdominal bloating." if value else ""}
{formtoggle: name= Uncomfortable abdominal distension; formatter=(value) -> " Uncomfortable abdominal distension." if value else ""}
{formtoggle: name= Excessive rectal flatus - flatulence; formatter=(value) -> " Excessive rectal flatus - flatulence." if value else ""}
{formtoggle: name= Excessive borborygmi; formatter=(value) -> " Excessive borborygmi." if value else ""}
{formtoggle: name= Fevers; formatter=(value) -> "Fevers." if value else ""}
{formtoggle: name= Night sweats; formatter=(value) -> "Night sweats." if value else ""}
{formtoggle: name= Rigors; formatter=(value) -> "Rigors." if value else ""}{endif}
