Currently one can only give a snippet
- a label
- a shortcut
- the content
Could we please get a fourth snippet field (optional, sure) to host internal notes about when and how it should be used? (You can only fit so much in the label!) Important for sophisticated snippets, esp in the context of team usage. Thanks!
Hi @Jacob_Lamoureux,
You can use the {note} command for that. Anything you place in a note block will only show up in the snippet preview and will not be inserted (although you can change this setting).
You can learn more about it here:
Ah cool ā thanks, @Cedric_Debono_Blaze! Thanks for schooling me on functionality that was right under my nose. Keep up the good work!
No worries. Text Blaze has so many features, it's easy to miss a thing or two (or twenty
