eu digito "posicionamento" e o trecho está sendo alterado automaticamente para "bilhete", alguém pode me ajudar com isso ?
Hi, and welcome to the forum!
Hi Jorge, it sounds like you have a snippet with the shortcut "posicionamento" and it is being replaced with "bilhete"? Is that correct or do I misunderstand what you are seeing?
está correto !
What would you like to happen instead in this case? You can change the shortcut of the snippet to change when it is triggered, or you can change the contents of the snippet if you would prefer something else be inserted.
