Example shortcut1, shortcut2, shortcut2, etc can trigger the same snippet
Use case: replace a collection of trigger words (to avoid) with an alternative word
It seems like this would also be covered by Regex shortcuts:
As a short-term fix you could create a separate snippet for each shortcut and use the {import} command to import a single source snippet into each one.
Sweet! Regex would handle this with perfection.
Is it possible to pass a parameter within the {import} statement?
You can't pass parameters, but {import}'s share the same variables as the main snippet.
So you can do something like:
{x=1}
{import: /something}
And the /something import will have access to the value of x.
Thank you - you genuinely saved my day
It’d be great to see this covered in the docs as well, especially a section on how to reuse and combine templated snippets
