OpenAI - Reformat Fat Paragraph
{openai-text: Reformat the following text to optimize it for mobile readability(generous line spacing), aim for 100 Flesch Reading Ease score, do not change/delete the original text: {clipboard}; format=formtext; name=text; trim=no}
To change fat paragraph like below:
Lorem Ipsum is simply dummy text of the printing and typesetting industry. Lorem Ipsum has been the industry's standard dummy text ever since the 1500s, when an unknown printer took a galley of type and scrambled it to make a type specimen book. It has survived not only five centuries, but also the leap into electronic typesetting, remaining essentially unchanged. It was popularised in the 1960s with the release of Letraset sheets containing Lorem Ipsum passages, and more recently with desktop publishing software like Aldus PageMaker including versions of Lorem Ipsum.
to skinny paragraph (readability)
It has been the industry's standard dummy text ever since the 1500s, when an unknown printer took a galley of type and scrambled it to make a type specimen book.
I'm using {clipboard} but you can change it to field etc. If you need 2-3 paragraphs, make sure to set the max token parameter. This is just an idea..
