Hi!
I was wondering if there is any way to integrate a PowerBI report in a snippet?
What I'm looking to do is having a simple diagram that shows customer agents progress, and make this visible in the snippet. I have both direct link and iframe code for the report.
Any advice is welcomed!
Can you make the diagram visible as an image link?
If so, you can use our {image} command to include the image in the snippet. Our documentation page (linked here) shows a bar chart example. Let me know if it works for you.
Thanks for the input - but no it's not possible to do this. I'll try to find a workaround
