I love TB and use it constantly at work! There is something I've come across that would be useful, though: if there was a way to select a toggle without manually clicking it with the mouse. I often use the keyboard to move between the quick entry fields, and if I press "Enter" while the toggle is selected (by pressing "Tab"), it inputs the whole snippet. Moving from the keyboard to the mouse is definitely doable, but I'd appreciate it if there was an option to allow pressing "Enter" on the keyboard to select a toggle option.
