Preview snippet
Just doing a bit of a test run with a few colleagues while we look for a snippet manager that suits the rest of the company.
One thing that feels a bit odd is that when you open the window using the keyboard shortcut, if you scroll down through your snippets using the keyboard, it won't give you a preview in the preview window. You have to manually click on the snippet to see it in the preview. But obviously it defeats the purpose of having keyboard shortcuts if you have to then use the mouse.
Is there a way to change this behaviour so I can see previews?
Hi @BBdee ,
Welcome to Text Blaze community.
Thanks for reporting the behavior. We will definitely consider this feedback to improve this behavior. I do not have a timeline when you would see this. But we will try to fix this experience.
I also moved your post to Feature ideas, so we can track it.
