I have set up snippet 1.
Within snippet 1, I have imported a snippet (snippet 2) where all of the questions reside. The questions are housed within a {note} {endnote}. Not sure if this will make a difference.
Within snippet 1, I have multiple other snippets (just say snippet 3) where all of the text that will be reproduced resides.
I have inserted a date field in snippet 2
{formdate: MMM Do, YYYY; name=datex}
I have also set up a text field to insert the number of days I want to add to the date
{formtext: name=enddays; default=0; cols=6}
I just cannot figure out how to reproduce a date in snippet 3 that is datex + enddays.
I have used
{time: MMM Do, YYYY; shift=+{=enddays}D; at={=datex}}
But when I do this it says "Could not parse "Mar 7th, 2024" as a date or time. Considering using the "pattern" setting" . Do not understand what the prob is because dates are in the same format.
Any assistant will be greatly appreciated.
