Good morning,
I have created a randomizer snippet in a folder which is shared with my whole organization.
When I use it on my account, it works perfect. When any person in the organization uses it, it pulls out the code instead of the random text.
Do any of you know what is causing this behaviour?
Hi @Martina_Toso1 - welcome to the forum.
Is it possible that the emojis you're using are from a specific pack that is only available to you?
No, this is not possible as I use them from Emojipedia, and as you can see, when my team use the command it publish the emojis, but instead publishing a single one, it just write the code for the random command in clear.
@Martina_Toso1 - AH, now I understand
They need to install the randomizer command pack from their dashboard. Otherwise, Text Blaze won't recognize the command.
Ahhhhhhhhhhhhhhhhhhhhhhhhh!
Such an easy solution! Thanks
