I have a snippet where i measure range of motion
i have set it up so that if i dont wish to record one movement it does not list but otherwise can call in movements using the if and import command
is there an easier way of doing this rather than having it for each movement
ie can the command repeat using a different dropdown item for each movement
at moment have numerous snippets for each motion 6 each side for shoulder and was going to do the same for elbow wrist etc, very tedious
snippet is :-
The Range of Motion Right Side was:
{note}Abduction{formmenu: default=Not measured; measured; name=Right abduction measured}{endnote}{if: `right abduction measured`=="measured"} abduction is {import: /rabrom}{endif}
{note}Adduction{formmenu: default=Not measured; measured; name=Right adduction measured}{endnote}{if: `Right adduction measured`=="measured"} adduction is {import: /radrom}{endif}
{note}Flexion{formmenu: default=Not measured; measured; name=Right flexion measured}{endnote}{if: `right flexion measured`=="measured"} flexion is {import: /rflexrom}{endif}
{note}Extension{formmenu: default=Not measured; measured; name=Right extension measured}{endnote}{if: `right extension measured`=="measured"} extension is {import: /rexrom}{endif}
{note}Internal Rotation{formmenu: default=Not measured; measured; name=Right internal rotation measured}{endnote}{if: `right internal rotation measured`=="measured"} internal rotation is {import: /rirrom}{endif}
{note}External Rotation{formmenu: default=Not measured; measured; name=Right external rotation measured}{endnote}{if: `right external rotation measured`=="measured"} external rotation is {import: /rerrom}{endif}
