Hi All,
I'm looking for the correct syntax to "paste" the clipboard contents as Proper text, but set up some exclusions.
with function: {=proper({clipboard})}
clipboard text:
MEDICARE BLUE NETWORK
reformat and fill as:
Medicare Blue Network
So, here's the twist: How do I add exceptions for specific text.
For Example:
MEDICARE BLUE PPO NETWORK
Would fill as:
Medicare Blue Ppo Network
What I would like is:
Medicare Blue PPO Network
I'd like to set it up so the proper function does not modify specific words such as PPO, HMO, EPO, POS.
Eoin
Hi Eoin,
Thanks for reaching out. You can add exclusions by using the replace function in Text Blaze to replace "Ppo" with "PPO", "Hmo" with "HMO", and so on, adding as many exceptions as you'd like.
I created a snippet below that does this with one of two methods. The first method uses a for loop to loop through all the exceptions, and replace the key (e.g. Ppo) with the associated value (PPO). The other uses a function called "reduce" that does the same thing on one line, which you can read about in the list function documentation. Feel free to use either version:
{proper_text=proper({clipboard})}
{exceptions=["Ppo":"PPO","Hmo":"HMO","Epo":"EPO","Pos":"POS"]}
{keys_list=keys(exceptions)}
{final_text=(input) -> block
var output = input
for k in keys_list
output = replace(output, k, exceptions[k])
endfor
return output
endblock}
{=final_text(proper_text)}
{=reduce(keys_list, proper_text, (text, k) -> replace(text, k, exceptions[k]))}
You can add as many exceptions as you would like to the exception list by adding another entry in the comma-separated list "exceptions" with the format: "proper version": "all caps version"
Let me know if you have any questions!
Best regards,
Alexander
