I confess that I don't know how to write regex but I have found examples on the forum that I've copied for my own use that seem to work pretty well. However the regex variable below has a problem wherein if an email address has a period in it then it will only extract the address after the period. Does anyone know how to modify it so that it will extract an email address that has a period in it?
Amazing! Thanks for the help. Could you also assist me with the "last name" regex? It adds a space at the end of extracted name. I've been cleaning it with a {key: backspace} command but I reckon it's better to get it right. I plan on learning the regex syntax at some point this year but I appreciate the help in the meantime.
