Hello! Is there anyway to remove the text blaze options from the right click menu in Chrome? Thank you!!
Hi Charlie,
Ashu has responded to your email.
Currently, there is no way to remove the Text Blaze options tool from Chrome's right-click menu.
If this menu item is unsatisfactory, you may wish to consider downloading the Text Blaze desktop app, which is available on both Windows and macOS.
May I know why you like to remove the menu item?
