I often copy large blocks of text from pdfs and remove the pesky new line breaks in paragraphs using
{=replaceregex({clipboard}, "\r\n", " ", "sg")}
but sometimes I copy lists and I don't know how to easily remove the bullet points.
example text:
paragraph text
⢠major list item
o minor list item
ideally the snippet would replace all ⢠and o characters with a new line break
Hey @jheilmann , you can nest the replace calls like so:
{example_text="paragraph text
⢠major list item
⢠major list item 2
o minor list item 1
o minor list item 2"}
{=replaceregex(replaceregex(replaceregex(example_text, "\r\n", " ", "sg"), "\s*ā¢\s*", "\n", "g"), "\s*o\b", "\n", "g")}
I used the regex \s*ā¢\s* to also delete (unlimited) whitespace characters (\s) before and after the bullet.
In the case of the minor bullet point, I used a word boundary (\b) to avoid matching o inside words.
That's awesome, I changed it slightly, because, as is, it caught the o's at the end of words such as "to" and I moved the "\r\n", " ", "sg" to the last position so it would only remove the new lines between bullets
{=replaceregex(replaceregex(replaceregex({clipboard}, "\s*ā¢\s*", "\n", "g"), "\s*\bo\b\s*", "\n", "g"), "\r\n", " ", "sg")}
thanks so much for getting me on the right track!
