I have observed a curious behavior with the clipboard.
Through TB I send with key-press command these two key combinations Ctrl+A and then Ctrl+C, to copy everything to the clipboard: {key: ctrl-a}{key: ctrl-c}
(Using the Cmd key doesn't copy anything)
Well, if I then press Ctrl+V, now on Windows, it doesn't paste anything, but if I press Win+V then I see that the info is in the history and I can even paste it.
Why can't I paste with Ctrl+V ?
Thanks in advance!
