Hi Guys
I'm hoping you can help me with a couple of things please.
Firstly, I've created the below snippet and most commonly use all the inserted snippets down to, and including, paced bottle feeding. I've read the "Tidying Whitespace" guide but can't work out how to remove all the extra whitespace while still leaving a line break between paragraphs.
Secondly, when I check the box to insert a snippet I then have to scroll down (often past a number of images) to get to the next one, is there a way to skip directly to each form toggle without having to scroll?
{import: /intro}
{import: /pos}
{import: /pain}
{import: /feed}
{import: /rps}
{import: /refusal}
{formtoggle: name=Settling techniques; default=no}{import: /settle}{endformtoggle}
{formtoggle: name=Fourth trimester; default=no}{import: /fourth}{endformtoggle}
{formtoggle: name=Sleeping; default=no}{import: /sleep}{endformtoggle}
{formtoggle: name=Safe sleeping; default=no}{import: /safe}{endformtoggle}
{formtoggle: name=Colic; default=no}{import: /colic}{endformtoggle}
{import: /wonky}
{formtoggle: name=Spit up; default=no}{import: /spit}{endformtoggle}
{formtoggle: name=Poop; default=no}{import: /poop}{endformtoggle}
{formtoggle: name=Baby wearing; default=no}{import: /wear}{endformtoggle}
{formtoggle: name=Hand-expressing; default=no}{import: /hand}{endformtoggle}
{formtoggle: name=Pumping; default=no}{import: /pump}{endformtoggle}
{formtoggle: name=Flange sizing; default=no}{import: /flange}{endformtoggle}
{formtoggle: name=Power pumping; default=no}{import: /power}{endformtoggle}
{formtoggle: name=Hands-free pumping; default=no}{import: /free}{endformtoggle}
{formtoggle: name=Paced bottle feeding; default=no}{import: /pace}{endformtoggle}
{formtoggle: name=Large breasts; default=no}{import: /large}{endformtoggle}
{formtoggle: name=Mammary Constriction Syndrome; default=no}{import: /mcs}{endformtoggle}
{formtoggle: name=Thrush; default=no}{import: /thrush}{endformtoggle}
{formtoggle: name=PCOS; default=no}{import: /pcos}{endformtoggle}
{formtoggle: name=Mastitis; default=no}{import: /mastitis}{endformtoggle}
{formtoggle: name=Premature babies; default=no}{import: /prem}{endformtoggle}
{formtoggle: name=Weaning off shields; default=no}{import: /shields}{endformtoggle}
{note}{formmenu: default=Please select one; Lyndsey Hookway; Additional Info; name=Especially worried about sleep}{endnote}{if: especially worried about sleep="Please select one"}{error: Select which additional info to include; block=yes}{endif}
{if: especially worried about sleep = "Lyndsey Hookway"; trim=no}{import: /lynds}{elseif: especially worried about sleep = "Additional Info"; trim=no}{import: /info}{endif: trim=no}
{note}{formmenu: default=Please select one; Sign off; Doing well; Trust your instincts; HC professionals (injustice); Antenatal sign off; name=How to sign off}{endnote}
{if: how to sign off="Please select one"}{error: Select sign off option; block=yes}{endif}
{if: how to sign off = "Sign off"; trim=no}{import: /soff}{elseif: how to sign off = "Doing well"; trim=no}{import: /well}{elseif: how to sign off = "Trust your instincts"; trim=no}{import: /instincts}{elseif: how to sign off = "HC professionals (injustice)"; trim=no}{import: /hc}{elseif: how to sign off = "Antenatal sign off"; trim=no}{import: /ante}{endif: trim=no}
Thank you in advance.
~ Bec
