Hi all, I am new to Blaze. I've created and used multiple snippets though. Suddenly, when I create one and then use it it basically command deletes itself. Any ideas? I type the last letter in the "/shortcut" and it deletes.
Hey Tiffany,
Welcome to the community and glad you found Text Blaze!
Do you have a snippet that has the shortcut where the contents are blank? It's normal for the shortcut itself to be deleted when you enter it, and for the contents of the snippet to be inserted. If you're seeing the shortcut get deleted but no content appear, then it's possible you have a snippet where the content is blank.
