Snippet Preview
Is there a way to have a snippet shortcut search populate next to the typing cursor (say 5-8 options) in a small box as typing occurs? I have multiple snippets that start with ";" + "acronym/subject" + "variation" (I'm in healthcare), but I can't remember the specific ending for each. This can get complex for each subject for history, plans, comments, assessments, etc.
For a simplified example, I might have the following for weight visits:
;hpiweighti (history of present illness weight initial)
;hpiweightfu (history of present illness weight follow up)
As I type ";hpiweight" - can both ;hpiweighti and ;hpiweightfu be listed as options actively next to my typing so I know what is available in my snippets without heading to the dashboard and doing a traditional search? I don't want the actual content of each snippet, just the shortcut names listed.
Hello Michael,
We're working on this feature but it's currently on beta. Let me know if you'd like to try it out, and I'll email you.
Yes, I'd love to try it out. Thanks!
Just bumping this, as this feature would be immensely beneficial and I'm looking for other products that support it. Currently, it looks like the feature is paused. :frowning:
Hi @michaelbenoitmd Welcome to the forum! :slight_smile:
Note that you can use the Text Blaze Assistant (https://www.youtube.com/watch?v=IIWQbcqH8mQ&t=0s) entirely via keyboard shortcuts: launch it via the keyboard shortcut, then use letter keys to search your snippet, then use arrow keys to navigate the list, and then press Enter key to insert the selected snippet.
You can also customize its keyboard shortcut. Would the assistant work for your use case?
@Obed_Parlapiano This function existed in Text Blaze but was removed after version 3.3.0; I would like to get it back because several of my snippets start with the same shortcut.
How do I get this feature back? That’s really what made me choose Text Blaze.
Hi @guilouz6 Welcome to the forum! :slight_smile:
Please note that this experimental feature was only available to a small group of users and has been removed based on user feedback. We are currently developing an improved version of this feature.
In the meantime, you can instead:
Let me know if it works for you
@Gaurang_Tandon Yes Text Blaze Assistant is working but that's not what I want; I'd like to get back the snippet preview that appears when I start typing a few letters, just like in the last working 3.3.0 version.
I use Text Blaze in my daily work, and this feature helps me save time (using the assistant takes longer and isn't practical).
Right now, I am forced to stay on version 3.3.0, unable to take advantage of the new features included in my Pro subscription.
We're working on surfacing relevant snippet shortcuts where you need them. Unfortunately, I do not have an ETA on when those could be available.
At the moment, to insert snippets in Text Blaze, you can either type the full shortcut, use the Text Blaze Assistant, or use the right-click context menu.
