Snippets double pasting
Hi, often (often enough that it is an issue), Text Blaze will double fill fields on websites.
So instead of https://llpgpro.com/397wtwgz/ it posts
https://llpgpro.com/397https://llpgpro.com/397wtwgz/
Using the Chrome Extension
Happens seemingly randomly. I need to clear my browser to get it to go to normal, but this is REALLY INCONVENIENT. What am I doing wrong, please? Thanks
Hi Brian!
Welcome to the Text Blaze community :partying_face:
Are you using one of our desktop apps? If so, please check the settings of the app to make sure that it's set to:
Screenshot 2024-02-04 at 8.44.32 AM
Thanks for getting back so fast. Yes, my desktop is set as you have shown (was set before you said to check-no change)
Hi @Brian_Walker,
Can you please let us know on which website/s, you are facing double trigger? For now, you can keep the setting as always disabled in Chrome to resolve the issue.
Hi @Dylan,
I am also having issues with snippets double pasting in Talkdesk, our company's phone system. This started a few weeks ago; before that, all snippets were pasting correctly in Talkdesk. It's not currently all snippets that are double pasting, just a few. No issues on any other sites.
I have tried deleting and recreating the affected snippets and it is still happening. I have cleared my browser cookies/cache and it's still happening.
I am not using the desktop app, just the chrome extension, so the above troubleshooting doesn't help.
Any ideas?
Hi Alyssa, I have responded to your email in our support.
If any other user reading this post is also affected with this issue on Talkdesk, please email us at support@blaze.today and we can provide workarounds and further steps.
same thing here
Hi @Michael_Smith1 welcome to the forum! :slight_smile:
If your issue is regarding Talkdesk, then we had found that adding formatting to your snippet should fix the issue. One way to add formatting is to select some white space and make it bold. This formatting would not be visible to your end users (because it's on a whitespace) but it should still fix the issue. Let me know if it works for you.
Another solution is to uninstall the Chrome extension and install the Text Blaze desktop app (Text Blaze: Snippets and Templates for Windows or Text Blaze: Snippets and Templates for macOS) which does not have this issue.
If your issue is not regarding Talkdesk, please let us know and we can assist further.
Good day, everyone,
I think I found the issue regarding the snippets double-pasting.
It has to do with the commands that start with "=" (f.e. =command).
I had it on every single command, and it was double-pasting on every website. However, when I changed my commands to start with "/" (f.e. /command) everything was fixed.
Please take a look into it, so you can fix this bug.
Best regards
Hi @anon19211533 Welcome to the forum! :slight_smile:
The issue is quite unexpected. Can you please reach out to us at support@blaze.today and we'll look into this issue asap? Meanwhile can you check if you have any conflicting extensions installed in your browser or any conflicting software installed in your laptop?
Best,
Gaurang
Hi @Gaurang_Tandon ,
Thank you for your reply.
I just reached out to the support. No, I do not have anything like that installed. I used to but I deleted it before installing Blaze as an extension.
Best regards,
M
Hi! I'm using Zendesk and snippets are double pasting today.
Yesterday it was fine before I upgrade my subscription. It's kinda inconvenient. Can you please help me? Thanks!
Dear @Cecelia_Rose,
Welcome to the forum! :blush:
Can you please contact us at support@blaze.today so we can investigate this issue further? In the meantime, please verify whether you have any browser extensions or software applications that might be causing conflicts with Text Blaze.
Best regards,
Gaurang
