I have snippets to help save files on my computer. They worked last week, but now when I type my shortcut, nothing happens unless I type it in the "Try it Out" section of my Text Blaze dashboard. Can anyone help with this? I do have Text Blaze installed on my computer.
Hi @shipping can you please email me at gaurang@blaze.today and we can setup a call to check this issue? You might have some conflicting extensions installed, and a quick check I would suggest is to: disable the other extensions and try again, or uninstall and reinstall the Text Blaze extension itself.
Best,
Gaurang
